Michael F
I recently acquired a pair of these and like them, a lot
. They replaced many far more expensive floorstanders in recent years that were without question more refined but ultimately nowhere near as enjoyable to listen to.
While the 683s are not perfect by any means either, I think I`ll hang on to them for a while which has me wondering if a crossover component upgrade may be a cost effective tweak that`ll bring their performance up a notch.
I have read on a European forum that these speakers respond quite favorably to better crossover components.
My biggest "gripe" with these is that I find the top end a little too polite, lacking some bite and sparkle that I know exists.
The same could be said to a lesser degree about the FST midrange driver but I`m nitpicking on both accounts here.
I`m considering replacing the tweeter capacitors to one of these two:
https://solen.ca/products/capacitors/silver-metallized-polypropylene-capacitors/solen-agm470/
or
https://www.partsconnexion.com/product49372.html
These are the two that are readily available and reasonably priced but I`d be open to other suggestions within the price range.
I`m also considering replacing the two generic resistors in the midrange band pass filter to some non inductive types while in there.
Depending on the results achieved by the HPF cap change, I may be tempted to replace the two midrange and woofer caps at a later point as they are of greater value and expense.
Your thoughts?
or
Your thoughts?
