Upgrading speaker posts on VTA ST70
brizey
Hi everybody. I picked up a beautiful VTA ST-70 that was assembled by a lady named Sue in 2013 (signed in the chassis). It is set up to accommodate 8ohm speakers only.
I want to hook it up to a pair of Klipsch Fortes which are 4ohm.
Anybody know what I'd have to do to upgrade this on the amp?
Thanks,
Brian
are you looking to have both impedance available, or just change the 8 ohm output to 4 ohm but keep the existing hardware?
Wow! Fast replies! Thanks! I was really hasty with that post. I cracked it open and I see that I can just swap the 8ohm lead from the transformer with the 4ohm lead. Looks easy. I guess I should not have shot from the hip like that. Thanks.
I do have a question. This amp is of unknown provenance, it came with a quad of EL34s that were obviously not original How can I I tell if this was originally wired up for 6L6 or EL34 type tubes?
If the output transformers are marked A470, its meant to use an EL34.
so far as I know though all versions of the ST-70 were meant to run an EL34
The VTA ST-70 is quite a bit beefier than the older ST-70. It can run quite a few other tubes than just EL-34 from what I recall about the one I had. I was running 6550's, I believe.
Doesn't the original ST-70 have screw terminals on the back for 4 and 8 ohm taps already? There shouldn't be a need to rewire anything, ya?
I put the speaker post's VTA sells on my VTA ST-70 aired for 8 and 4 ohm.
There are twondifferent power transformers used on the Dynaco ST-70's.
The earlier versions had the smaller transformer. The later versions have the bigger transformers and can use KT-88's and 6550's as far as I know.
I found using KT-88's just didn't sound quite right to me. Probably because
The amp is optimized for EL-34 types? :dunno:
Aren't all Forte's rated at nominal 8 ohms?
Early original Fortes with round terminal cups ware "marked" as 4ohm. The later version of Forte 1 with a square terminal cup were "marked" 8ohm. I don't know if there was any difference between those versions electronically though. I have 2 sets of early version and I always ran them on 4ohm taps of my equipment.
