Hello folks,
My Yamaha ca1000 integrated needs two new 18000uF lug type electrolytic capacitors as they are leeking badly, but I cannot source any in the original size which is 50d * 80 H or anything of smaller that will fit the space on the cap circuit board.
This size is the max that will fit in the original position due to the amplifier being so tightly packed with other components around the caps.
I have also looked at the 22000uF caps, but no luck in finding a size that will fit 2 caps in that spot side by side like the originals.
The brands I have looked at are Mundorf M-Lytic, Nichicon KG and BHC slits.
I cannot think of any other brand that makes good quality power smoothing caps.
If anyone has done this mod to a similar yamaha ca1000 amp recently, and advise where they sourced their caps from would be greatly aprreciated.
I reside in Australia so most likely I will have to have any caps imported from overseas.
If anyone does know where I can get the correct size caps, I will also be able to go ahead and replace all the electrolytic caps on all the boards as I have the original service manualfor the Yammie.
If I cannot find replacements to fit, I am afraid this amp will be ending up at the tip, and I do not want to do this as this is one of the sweetest sounding amps I have ever owned and I really want to fix it.
Thanks in advance folks
Cheers
Theokalat
Cheers
Theokalat
