USB cable over 20 feet long
I have a PC using windows 7 and a stereo system 20 feet away from it. I have a Moon 350P with a phono preamp and a USB input. I think the 350P has the same female input that the PC has. If it does, then I must buy a cable that has males on both ends. Also, it must be an "actice" one to compensate for the extended length.
Question #1, is the Moon input a female, and, question #2, will the active cable degrade the signal input to the preamp?
Thanks for any ideas.
BB
BB
The USB 2.0 specification states that a cable should be no longer than about 16 feet. Longer than that, and it might or might not work. Your "active" cable should be effectively like two eight-foot cables, which should be fine. Digital signals don't degrade in the same way that analog signals do; they either work correctly or they cause very audible drop-outs; the effect of a degraded or non-working digital connection will not be subtle.
