Hello, Folks.
I'm in the middle of restoring 2325. I got this with unknown condition. Powering on, but no relay clicking ever.
I decide to get full restore kits, hopefully getting fixed from replacing parts. I got kits from bay seller who does marantz parts mostly, I had few times from him for different models, always good result out of it.
Processing to restore 2325, when I finished replacing components on each board, I plugged in a 200W DBT to test to make sure I didn't make any mistakes in soldering jobs or put in backward, each time testing it's always quick bright then goes dimming down to off, but not heard relay clicking.
I did not replace the PL01 Dolby tone and meter board, and P600 Dolby board components came with kits.
However, almost the last task was replacing big filter capacitors that came with kits. Original is 15k uf/70v, new one is chemicon 22k uf/80v, with 225k film capacitors on for each. After that, DBT again. it makes quick bright and then trying to go down a little dim then coming back to brighter like the first moment powering on.
Like this, when the power switch on the bulb turns bright for one second and goes down dimming for 2 seconds then coming back bright with two three seconds. I didn't wait more than 5 seconds to turn off and make sure not to burn anything from shorts.
My question is, am I using the wrong wattage bulb for this test or there is something badly shorts for this to happen?
I read others posts that said I need 100w or 150w DBT for 2325, but I only have 60w, 75w, and 200w.
I still have not heard the relay click yet.
I appreciate any input.
