Lavane
Lunatic Member
I ordered a set of 6P14P-K's for my Magnavox 9304. They're basicly a rugged version of the 7189. What I was wondering is, will running them at around 300v instead of 400v really shorten the life of these tubes? The 6P14P-K's are rated for 5,000 hours. I read somewhere that running them at the same voltage as a 6BQ5 will shorten there life to around 1,500 hours.
I'm not worried about that too much, since a matched quad was pretty cheap.
I was just wondering if it's true that the tube life will be shorter running than at a lower voltage.
I finished up making a few changes to the amp and it still sounds pretty good even with the very weak original tubes. The new tubes should be here in a couple weeks.
