Checkylad
unning a 12" passive sub from my AVR to the sub then out to the main L/R. Have the AVR sub setting on OFF. Adding a 6" active sub. If I connect through the LFE will it work since the AVR sub setting is OFF? How should I wire the active sub....I want to be able to use the crossover and phase, etc. on the back of the active sub and not go through the AVR bass management options. Should I connect the active sub to the front L/R B
and run both A/B on the receiver? Should I use an unassigned/available surround? If I use the LFE and set the AVR to sub ON then how should I set up the passive sub.....I want to use both the active and passive sub.
If I use an old Kenwood stereo amp to power the passive, how will the music get from the AVR to the passive sub?
