Why are you wanting to hook up two receivers up, one of which has no capability asa pre-amp(SX-780)? The Onkyo is rated for 100WPC.
The only thing I can think of is the ONKYO's Tuner is KAPUT and you want to use the 780 as a tuner. In that case run the tape loop, OUT from the pioneer, to either the TAPE LOOP IN or the Aux jack on the Onkyo. They are all line level inputs/outputs and should pretty well match impedances. Run all external sources thru the 780.
NOTE that running this way you WILL NOT have control over the VOLUME, TONE CONTROLS, BALANCE, Loudness, or the LOW FILTER on the 780. You'd still have to work the Onkyo's controls.
Larry
