Using a Sunfire sub with a Eico ST40
iplagolf
Well-Known Member
Had a thread about subwoofers a few weeks ago, best, what would you use, etc. Did some research and bought a Sunfire SDS-8, Bob Carver design, subwoofer. It has RCA input jacks. The Eico has screws on a speaker strip. The Eico has a center speaker port. My thoughts are/were to integrate the subwoofer into the center speaker port. The sub is adjustable from 50 Hz, 100 Hz, 150 Hz with its own power amp. I'm going to make up a female RCA jack to forked plug end to accommodate the sub. Since this is a "mono" hook up the directions say to use the sub/LFE output (center speaker) to L/LFE input (sub). My thoughts are the signal from the amp (bass) will be processed by the sub in the desired range and boost the bass. It's going to be a few days before I can hook the sub up, but am I on the right track or off the mark? If you have an older amp, tube or SS, how did you hook yours up? Thanks, Fritz
I think you confused me. How are you trying to hook up the sub? You mean you are trying to run a cable from the Eico's speakers output to the Sunfire's RCA input?
If that's the case- DON"T!
The speaker outputs will damage the subwoofer. The RCA's aren't speaker level, meaning they don't carry the same type of signal. I'm sure someone else will chime in with a more detailed explanation.
