I assume 500 Hz capability matters to you. Go to the BMS site and look up the specs of their 1.4", 1.5", and 2" drivers. 511E horns are 1.4", as I recall, but they are merely 511s with the throat lopped off at the appropriate diameter and a mounting flange added, which any competent machine shop can do.
The most direct solution to your problem is an active crossover with CD compensation like Behringer CX3400, ~$150 complete with cables at Guitar Center or similar source. AK members have been securing them there for $99 for the unit itself lately....
I have the Behringer, ready to go active, and am looking forward to using it.Yes, but for a few pennies more, the quality of 260-262, the 100-Watt version, is better.Zilch, will the 260-252 L-pad from parts express work for adjusting R2? Thanks
Yes. It prevents the impedance from getting too low, although you'll see even that starts pulling the whole works down, including the HF, at the lowest resistance settings....OK let's see if I got this right, off terminal 2 of the L-pad I run a 2-ohm resistor back to the negative, this should take the place of R2 in the 30923 schematic? Does the 2 ohm resistor provide the circuit with extra resistance when the L-pad is at zero ohm's?
