Try to avoid the habit of wiping glue drips with your finger.
Now I ask a big question... why use hot glue at all? Hot Glue may damage some components, distort some plastics, and not adhere all that well to some materials.
I want to suggest using another glue... one that I use here in my own workshop on electronics and musical instrument repair.
I use a class of adhesives known as "SBR adhesives". SBR is Styrene Butadyene Rubber. These adhesives are glass clear, bridge gaps well, adhere to dissimilar materials very well, handle vibration and stress better than many epoxies because these glues are slightly flexible when dry. One drawback, the solvents in these adhesives MAY damage some plastics. It would be good to test first.
I use these glues for saxophone repair for gluing on the keytouch pearls, felts, and something I do, custom key appliances. What are these? These are risers on keytouches that enable better reach for some people. See my article here on prostetic work:
http://www.saxgourmet.com/PaulCoatsArticles/fabrication_of_prosthetic_key.htm This article has some photos, too, please, read it.
So, where do you get these marvelous adhesives? There are three that I use.
E6000 by Eclectic Products. This SBR adhesive is the thickest, thicker than silicone caulk or epoxy. I use this for gluing heavy crossover inductors, other heavy parts.
Aleene's Platinum Bond 7800. This SBR adhesive has a viscosity similar to freshly mixed epoxy, perhaps a little thicker. E6000 and Aleene's 7800 are usually found in craft and hobby shops, or the craft section of Walmart.
Seal All. This is usually found in automotive shops and hardware stores.
I suggest you buy all three of these adhesives and experiment with them, see what they will really do. I think you will be impressed with the excellent bond without the brittleness of epoxy. And if you want to remove a component glued with these adhesives, just slice through it with an Xacto blade or sharp knife. You can even scrape off the residue with your fingernail, leaving a clean surface.
