audmod01
The X-101C I have is missing its original volume control. I did manage to find a Fisher dual volume control without the AC switch (not a type that can have one added). I see that there is some room between the front panel and the chassis front behind that. I am considering the possibility of adding a small cam to the volume control shaft (perhaps by soldering) and using a microswitch to do the AC on-off function. Another possibility is to use a slide switch where one of the original slide switches was located. I am doing Dave's X-101C modifications and the High Filter switch position could be used as I am deleting that part of the circuitry.
Another possibility is to use a separate bracket behind the front chassis panel to mount the volume control recessed more to the rear and add a microswitch there. The shaft on the volume control I bought is about 2 inches long, so I have plenty of length to play with.
Has anyone else considered using a microswitch?
Joe
Joe
