Thunderbox
I have come to a conclusion, vacuuming records to dry them, may not be the best option. I have used many ways to clean records but no matter what, when I looked under the microscope they just were not as clean as I expect. I have experimented with a lot of ways to clean. Why was there still, (using a microscope) a lot of dust and silica on the surface. How is this happening? I have washed records using a 3000psi pressure washer, Spin Clean, Ultrasonic Cleaner, In the sink with dent pullers and paint brushes, Canfab 2 RCM, Clearaudio Double Matrix Sonic Record Cleaner and after the complete regimen all resulted in the same problem, too much dirt. These were the pops and clicks I could hear. I have to wonder, what is the common theme here. Hits me all of a sudden when I was watching TV and a strong beam of sunlight came into the room. The airborn dust was awful. The problem was vacuuming in the last stage of record cleaning. Huge amounts of dust are everywhere in most rooms. Everyone has seen this thousands of times. It's so obvious. Almost all contaminates on our records comes from the air. So maybe, just maybe, sucking dust filled air over the surface of a damp record, is causing the problem. As you vacuum, the make up air rushes in from the room to replace the air you sucked out. This is dust ridden air we see in the sunbeams. It would be very difficult and expensive to build something in which the air quality could be controlled while vacuuming. My latest and ongoing venture into an affordable record cleaning method, seams to have proven that vacuuming, was the problem. So I just stopped vacuuming. After pressure washing with DW I put the records in a vertical rack for drying without vacuuming. The room is 8 by 8 ft and has a small filter running 24-7. Same room I have always used for the majority of my repairing TTs, vacuuming and record cleaning. Couple of hours later, I looked with the scope and they were exceptionally clean, I put them on the tt and they were very quiet. I think my vacuuming record days, are over. This could potentially remove, one of your more noisy and tedious cleaning steps and result in cleaner records. Have a it people.
