QSilver
I've been working through a Pioneer LX-420A valve receiver. I've replaced the electrolytic capacitors and got the FM MPX working again along with the amplifier circuits. But I've got a problem with the AM tuner.
It looks like when you switch over from FM to AM, the FM front end is switched out together with V10 and the AM front end is switched in, together with V14 - a 6BE6/EK90.
The problem is, that FM works fine, but switching into AM causes the tuning needle to peg to maximum and the tuner goes silent. No hiss or anything.
I've checked resistors around V14 and values look ok. Am I looking in the wrong area or missing something? Where do I go from here?
The LX-420A I think has some similarities to the SX-34B if that helps at all. I think mostly the differences are that this unit can tune into FM/AM/LW/SW
