Valve Matching For Fisher X-100 A
DG Nelson
There is a missing 7189 valve as part of the output stage for the Fisher. I'm looking to order one online (tung-sol from Russia) where they say you can order a matched pair. Is it important to get a matched pair?
Thanks
Dan
Without bias adjustment on the Fisher X-100-A, yes you should get a matched pair. Better yet. A matched quad. I'd suggest an IBAM or IBBA for some flexibility.
BTW, are you talking about EL84M tubes? Or have you found a source for new manufacture 7189 tubes?
DG Nelson; Factory matching is for mutual conductance not Cathode Load. You want the cathode draw (load) to be within a couple of ma. Factory testing doesn't account for that. Try Jim McShane, he has them for $64.50 a quad MATCHED at operating voltages and Cathode draw. Something that you won't get from the Valvestore. If you're down under, shipping may be a NO-GO.
Tim; EL84M are Sovtek's. Tungsol el-84 ReIssues are relatively new. There are 7189 clones that don't make the cut for Vox AC-30 type amps. Apparently this is the most reliable of the very few that do make the cut. Haven't tried them yet, but eventually I will.
