Its a nice amp stock and I've heard the VA Mosfet mod is pretty good although I've not heard one directly. I agree with the cap mod and the RCA mod although I personally hate where Dynaco put the inputs (middle and below the heat sink fins, a PITA to reach). The speaker binding post mod is pretty SOP for Dynaco units.
At the price of $140, a decent deal, would be nice to get it for a little less as stock units can go for $100 or so. If the unit is clean and well kept cosmetically, you could do a lot worse for the money.
BTW, the stock units can be modded with some PS mods to give about double the power. However, I don't know if that would apply to the VA mod since I suspect he changes the entire circuit board.
If its local to you to avoid shipping charges and possible damage, its a good deal.
There's also a Crown D150 and Yamaha CR2020 both at $300 in the same CL section. There's also an Accuphase E-202 for $450, really nice but out of your price range. There's also a Yamaha P2100 pro amp (85w/ch into 8 ohms) but it doesn't like 4 ohm loads too much, mid 70's design for $145.
However, all these vintage amps may at some point need maintenance and/or repair. If the VA mod was done recently, that is a plus.
