electronhick
How warm should the regulator transistors get? TIP 29C and TIP30C? Running approx 130F and climbing.
How warm should the Driver and Output transistors get? TIP32C and TIP31C, 2SA1386 and 2SC3519. Running approx 130F.
Sub is about half volume for almost two hours.
The slab heat sink will get over 130F
DC offset is low (10mA) and idle current difficult to measure because goes into protect mode when I measure across the emitter resistors. Emitter resistors are 0.1 Ohm.
