I have a marantz case that is 90% good to ok - some scratches, but easy to sand & refinish - except for the big chunk broken out of the top rear where something heavy was dropped on it. I know I can rout out & piece in some MDF to rebuild the case & then add a piece of veneer, but I'm not sure what will match. I've been told the marantz veneer is walnut, but all the walnut I've seen is darker. Can walnut be bleached somehow? Alternative wood - like mahogany? I can live with a patch being noticeable, just not screamingly obvious.
If patching isn't practical & I reveneer the whole case, should I lay the veneer over the existing stuff or should I strip it? I'm thinking that trying to strip off the good veneer could easily trash the case completely.
Thanks,
Tom
Thanks,
Tom
