Vertical Corns
GTOChris
New to the Cornwall seen so please excuse my apparent ignorance, I just picked up a pair of early vertical Corns with cross overs clearly marked type 2 R and one has a bad tweeter diaphragm, the cross overs have the paper and oil caps, I assume these are the 16 ohm set ups which as I understand the replacement diaphragms are not made any more.What is my best approach from here? I look forward to your input. Thanks
on their sides the Corwall will fit under a standard window frame same with a
belle and a LaScala (I believe). Best regards Moray James.
set-72157634237638300
Were the verticals designed to go in between 2 Khorns?
only rendering I've ever seen shows regular Cornwall
https://www.flickr.com/photos/klipsch_audio/5534826975/in/set-72157634237638300/
Those are a beautiful looking set of Birch veneer Decorator verticals, lovely patina. Do you know if horizontal cabinets were made with vertical horns? Thanks for posting the picture. Best regards Moray James.
They may be shown as vertical but the orientation of the mid horn means they should be laying on the long side horizontally. According to EV the vertical orientation of the T35 tweeter gives the best horizontal dispersion. There is a Klipsch owners forum that shows drawings of all the Klipsch passive cross over networks from way back when they were using 6/db crossovers.
