Victor (JVC) QL-A75
The Fez
Well-Known Member
Just getting back into vinyl. Got this TT from a guy down here. Very happy with it. Needs a better cart in it, but its a good start, nice arm I think.
It needs a freshen up, but I'd like to know if the plinth is a real rosewood veneer? I have some evidence that it may be. Can anyone confirm if its timber or a faux /plastic coating..
Thanks everyone..
attachment.php
Thanks AS yes its a nice table. My question is related to the refurbishment, and its potential. Knowing about the finish on the plinth will determine related efforts.
It's faux veneer, not real wood. I own the Y55F which is the auto version.
If it's veneer it's probably pretty thin. I'd check the owners manual from VE to see what JVC recommended using to clean it. Your JVC deserves a decent cartridge and it should reward you highly.
If you go to the back of it and prick it with a pin you should be able to tell if the surface is wood or plastic. Plastic will leave you with a round hole whereas wood should leave a slight slit or crack, which will likely largely close up again.
Nice looking table btw.
Steve
Thanks all -- really appreciate all the excellent advice..as always...Certainly be upgrading the cart. Initially looking at the Ortofon 2M range. Red, Blue, Bronze etc..
Hey jkilla-- .Current cart is a Excel ES-70E. I think that a budget cart...But I defer to you guys who know wwaaayyyy more than me.....
I'm looking at the Ortofon 3M range for this..Red, Blue, Bronze etc....Any suggestions welcome. I think for this TT a decent cart up $400 -$500?? Have read that Denon MC seems to suit this table?
BTW -- You must be happy with the 2014 nominations for the rock and roll hall of fame.....given your avatar..Thanks ---
That beaut table can go with a lot higher cart than that mate.
Try an Ortofon Rondo MC maybe ?
Weverb ^^ just installed a Dynavector XX2 Mk1 on his and it sounds glorious, even better than the DV Karat 17D2 it replaced (as it should). The Karat 17DS on mine sounds fantastic to my ears. So yeah, the turntable can handle carts way up the food chain!
Hay Fez :)
Absolutely lovely table!
Better than my still nice 838, and I have a 2M bronze and could easily make use of a Black, so you would be well justified in mounting one of those if they suit that arm.
I love the Bronze, and would like a Black. The Bronze is well balanced and digs out a good amount of detail (not as much as the Black I hear) and occasionally digs a bit out that surprises ya'.
While I haven't any first hand experience with the Black, I have read that it is more detailed than the Bronze but can show more surface noise. The Black is said to be more lush, with a noticeably deeper sound stage.
I guess It comes down to suitability to the arm, and what presentation you are looking for.
In that bracket, there are probably a few very nice carts to consider.
Thanks-- excellent, excellent. Gee I'm really enjoying vinyl again. Actually bought my first new LP yesterday, ....since 1980....... John Mayer Continuum... :music:
Can you give me a $$$ figure on these carts...When I think Dynavector I think BIG bucks.. I'm sure the TT / arm can take a really nice cart -- I'll set my budget at say $500.
My approach would be to first look into arm mass and cartridge compliance - make sure you are selecting something that is a good match.
Next thing to look at is your phono stage, and cartridge loading...
If considering MM/MI cartridges (like the 2M's) you need to find out what the total capacitance is (including both arm/interconnect and phono stage) - and make sure you are 1) within the recommended range for the cartridge, and 2) preferably within 50pf or so of the optimum for the specific cartridge.
Many MM and MI cartridges will also perform better at a different resistive loading than the standard 47k.... (eg: AT440MLa likes circa 35k, many Grados work best at between 10k and 35k depending on model and stylus fitted, etc...)
MC's also have loading requirements and their needs range from 30ohm to 1k ohm usually (although some have other requirements)
And then there is gain - MM's with 4V or 5V outputs are the most common, and all MM stages will handle these well, but some of the best MM's of yesteryear had outputs that could be as low as 1.5V
Also many high output MC's have outputs in the 1.5V to 2V range
So the gain needs to be right for the cartridge
With low output MC's gain becomes even more important as there is a wide range of possible signal levels... and therefore a wide range of possible gains required.
Depending on budget, you may or may not want to replace the phono stage along with the cartridge... if not, then the parameters of the phono stage will also be a determinant of suitable cartridges...
just my 2 bits
bye for now
David
