Vifa tweeters
Taylor S
Hey guys, i recently bought a pair of paradigm 3se speakers off kijiji for $40. One woofer has voice coil rub and one of the tweeters has a piece of plastic broken off the housing. I replaced the woofer with one i had from a single 5se mkII i had laying around so no issue there, however the tweeters are different. I salvaged the tweeters from a pair of mirage 360 bookshelves with almost identical vifa tweeters. The mounting depth is the only difference i can seem to find with the tweeters. Label from the paradigms is "d25t6-55 06 ohm 909. The mirage tweeters are "d25t6-55 06 ohm 910". Does anybody know of the differences between the two? Ive placed the mirage tweeter in the paradigms and cant seem to hear any difference between the two but a little feedback would be appreciated.
I think the only part of the model number you need to worry about is the "d25t6-55 06", which probably explains why they sound the same.
