Vintage Ampex Crossover Cap Help
SCI OTR
Member
Happy New Year,
I am a noob and would like some insight. I seem to believe the 1 capacitor is for the mid/high speakers, in a 2 way design. 1 mid, 1 tweeter. 1 woofer.
I posted a photo of the capacitor, only 1 for these speakers.
Can someone help me identify these as "original", and what I should look at for replacements? I sure there are numbers associated with these capacitors, and I assume a new one with the same specs is the right approach???
I can update with better photos after removal of these, if it is even necessary. I want to make the right decisions.
Help please, and suggestions.
Thanks.
...Can someone help me identify these as "original", and what I should look at for replacements? I sure there are numbers associated with these capacitors, and I assume a new one with the same specs is the right approach???
You are correct in that there will be numerals on the original cap, next time you're in there use a magnifying glass to get a closer look, write down what you see and let us know and we'll point you in the right direction with regards to replacement.
As it is the pic is blurry and far away to identify
Thanks so much for reply, much appreciated.
Do these appear to be the original capacitors?
I finally got around to opening the Speakers and taking better photos of the capacitors. See attached photos below.
First, are these electrolytic caps? 5MFD 50VAC
Second, what do you suggest I use for replacement? Dayton Film Caps from Parts Express?
Third, is there polarity associated with capacitors? This cap does not seem to show + -...?
Any and all suggestions is appreciated, as I am a total noob and this will be my first time doing this.
That looks to be correct as to Dayton's or from Parts express, you can find these at a lot of different places such as
Mouser (No Affiliation)
DigiKey (No Affiliation)
The above get mentioned in good esteem here a lot, so they are legit
Parts Express is good too
As to Dayton's specifically I have no experience with them so hopefully others will chime in who do
