Poultrygeist
Lunatic Member
Without mentioning it explictely it the Nelson Pass article explains why there are at times heated disussions of how much power is needed to drive certain speakers. I recently saw an thread on another website about a guy who blew up not once but twice some expensive Lowther full range drivers with his esoteric Kenwood KA-9X amplifier. I suspect he wanted to get more bass.
On Pearl's HiFi website is a trove of interesting articles (no affiliation, just a customer using some of his tube coolers) and one of them has to do with damping factors writen by D.J. Tomcik, Chief Electronic Engineer, Electro Voice, Inc. (Attached).
A short side step (not on tube coolers to extend life): the military did extensive studies and discovered that repeatedly removing tubes from their sockets and testing resulted in a shorter life span. Recommendation was to test in situ.
The military also discovered that if equipment is run in a controlled environment tube life can be twice as long.
The mains these days flutuates a lot and neither is it nicely sinusoidal due to all the switched power supplies, speed controllers and what have you.
I am piggybacking my tube amplifiers on a 1.8 kW UPS that I use to convert our 50 Hz mains to 60 Hz for some other equipment. This UPS has a stable voltage and pure sinus output reducing the stress on the tubes.
AM
Lowthers are fairly robust for an HE speaker and can handle 100 watts with ease. But no sane person would want to be in the same room with them at that level.
