it all depends on what holds your rear in the listening chair the longest. If you are listening, get bored and get up and walk away, not so good.
But if you want to keep going into the wee hours of the night that is a different story.
so, the key to measuring has to with measuring the glue bond joint between your rear and the seat. If its super strong and resists the tensile pull to get up you are on the right path. If its weak and you get up and wonder away after 15 min, then you need a stronger glue,,,,
