Still digging the 800+? Glad you're still enjoying it; very nice receiver...
Yes, using an EQ or the tone controls to boost the bass or treble can cause the amplifier to clip at a level that produces much less sound than if you used a "flat" setting. The more you crank up the bass and treble controls, the more of a problem you will have.Just a point to consider: When you use an eq to boost a signal, you suck the watts right out of an amp and increase the possibility of clipping at a "lower" level than you normally would.
Half power? Do you mean turning to volume half way up? If so, you should know that most, if not all amplifiers, reach their maximum rated power well before the volume control is advanced to MAX. This is especially true if you turn up the bass and/or treble controls or use the “loudness” feature.I never knew that, thanks for the insight! But I NEVER play over half power, thats my rule![]()
All things considered, the much lower power provided by the receivers you are considering will probably leave you disappointed.
It depends entirely on the input. The volume is just turning down the input by X amount and the exact position doesn't really mean anything about how much power you are using.So are you saying greater than half is max RMS or fewer then half? most of my listening is between 1/4 and 1/3
