The Amp
I just purchased my first ever vintage amp off eBay (Yamaha CA-610 II). The seller said the pots and switches were cleaned and the unit looks in great shape.
I tested it with an iPod in the AUX input and it sounds AMAZING! Even at 100% volume it's very clean with zero distortion. I'm impressed!
I then unplugged the iPod so there was no input source at all and turned all the pots and flipped all the switches and found:
The Issue
A very slight static / crackle only in the left channel when adjusting the volume knob.
A very noticeable static / crackle only in the left channel when I turn the REC OUT selector switch (even just a touch or wiggle of the switch causes the crackle).
I tested both the A & B speaker outputs and I switched the speakers and wires to eliminate that as a possible issue.
All other pots and switches there is not even a hint of static / crackle in either channel.
The Questions
Why is the static / crackle only in the left channel?
If the issue is in the REC OUT selector switch why only in the left channel?
Is "more DeOxit" worth a try even if it's been done recently?
If I cannot find and fix the issue can I just disconnect the REC OUT selector so even if it's touched or turned there is no static (would disconnecting it cause any other issues)?
Conclusion
I'm excited to get into vintage audio and any suggestions or info on how to fix this left channel issue would be appreciated!
Thank you,
Mark
The Issue
The Questions
Conclusion
Thank you,
Mark
