Infantry Man, I think you got a really nice haul there!
Looking at the stack in the rack, you may have a very interesting receiver there. Technics has a line that used what they marketed as “New Class A” and it seems like that might be the tag on that receiver. It is well-received. Google “technics new class a” And you’ll see good info - here on AK and elsewhere, like DIYaudio.
Might have some other nice gets in there as well.
I think you’ll like the speakers as well. Do starters, they look great! Walnut veneer all around. They refinish very nicely. A couple tweaks I did to mine that made a big difference:
First, I added bracing in the cabinet. Big difference in the overall character of the bass and mids.
The woofers run without any inductors and are meant to roll off smoothly on their own. The tweeter is a cap only. Replace the original cap. Both woofers and tweeters run through the L-pad. The stock tweeter is disappointing. I replaced mine with a phenolic ring tweeter I picked up from Parts Express. I feel it is much nicer. Make sure, also, you check that both woofers are working. They are 16 ohm wired in parallel. When I played mine it sounded like they were working fine.
