berkemo
Working on a Motorola Model: 13KT15CW Chassis: Ch= HS-677. Just finished recapping the filter caps, all paper caps, and cleaning tube leads. The amp sounds great but the radio needs some tweaking. Generally it works pretty well but the issue at hand is that I've got a couple of strong signal stations on both AM and FM that really distort at max signal. As you approach and leave max, the station is legible but not clean. I've been searching the forums for ideas and it looks like the issue might be centered around AVC/AGC?
My question is: are there any 'top level' troubleshooting steps a newbie could do to address this issue? Things like: other caps I should look at? Tubes I should replace? Antenna issues? Specific resistors to look at?
Help! Thanks.
Help! Thanks.
