can you supply some pictures, or a chassis # ?
at the very least, you'll want to add a power switch, fuse, new power cord, and recap the power supply and output stage . . .
depending on the model, you may need to change a couple components in the signal path, but this is usually very easy if you know how to solder - just be careful - VERY high voltage in these amps ! :thmbsp:
