buckeye56
Hi. My old Technics SA 205 receiver is super hot underneath on the left side (me facing the front of the unit). It's like this if I listen to the radio, play CD, etc.The right side is cold. Only two bookshelf Polk speakers are connected, a turntable, and a DVD player, but obvs I only use one device or just the radio, at a time. The vents are on the top and there's nothing blocking them, not even a shelf above. The receiver sits on a table. Oh, and when I lean into it, I can "smell" the heat.
So what's causing this, and is it going to blow up or something? I thought if I put some kind of wire/mesh riser underneath it may help, but if the vents are all on the top, then it seems pointless.
As always, thanks!
As always, thanks!
