Vintage sampler
audioagape7
I think someone should create a sample bank that would reproduce the sounds of different audio receivers; you could hook it up to your system and it could sound like whatever vintage gear you wanted , but then I suppose it would just be on the macintosh setting all the time......
Or like listening to a person's system on Youtube to hear how good they sound, but overall they won't sound any better than the speakers on your PC.
What would be interesting is to choose some standard program material and run it through various vintage receivers, loading the output and recording a divided portion of that output signal to a file. Naturally the levels would have to be perfectly matched/standardized. It would be interesting to hear the differences, if there were any. My guess is they'd be smaller than commonly believed. But, I've been wrong before- you can ask my wife! It might also be interesting to do the same thing with restored vs. non-restored electronics.
I have seen some guitar amps and effects that work on this principle and seem to do a pretty good job.
Those guitar effects to which you refer are intentionally designed to distort sounds in an effort to "produce" music. IOW, that guitar "distortion"* is part of the intended final result. I do believe the "effects" to which you are initially refering to are much more subtle than that and are designed to REproduce music as exactly as possible.
* and that's exactly what it is. Intentionally introduced distortion,
no this is actually an amp that reproduces the sounds of different guitars matched with amplifiers it worked by sampling I believe.
Yes, and the real gear beats DSP modeling. If I want to hear a McIntosh, a Marantz, a Yamaha or any other I need to hear the actual unit. Likewise, if I want to hear a Marshall amp, a Fender, or a Vox amp, I want to hear the amp. Simulations however good don't get you the true experience in either discipline.
