I'm a recently converted audiophile and am looking to get a good system. I'm on a really tight budget and plan to couple some Dayton B652 speakers with either an integrated amp or receiver.
I had my B652 speakers paired with a Technics SA-5170 and was pretty happy with their performance together.
As it is, Parts Express is selling the B652 speakers in a bundle (that I
reviewed) with a DTA-1 T-amp. It's not a bad little bundle.
One thing to be aware of: the B652 speakers say "8 ohms" on the back. In reality, I found two eight ohm drivers inside, wired in parallel (with a capacitor for crossover purposes). This will (and does, per my multimeter) cut the impedance in half, to around four ohms. Be sure that whatever you pick can safely operate with only a four ohm load.
Most sets can do so when only one pair of speakers is involved. If speakers are placed in series when more than one set is switched on, using more than two four ohm speakers will be safe, as the impedance will go up. Some sets place their speakers in parallel (lowers resistance) and others place them in series.
Simple test: Play the set with one set of speakers attached. Attempt to turn on the other set of speakers (with nothing attached to the terminals for a second set of speakers). If the receiver continues to play with both sets of speakers turned on, it parallels them. If the music stops, the receiver or amplifier places them in series.
If oodles of purple smoke appear, I don't know you and you never saw me.
The suggestion about hitting thrift stores is a good one. I'm sure you can find something.
I would recommend buying a tested receiver from a source with good feedback, especially for packaging. If they don't know how to pack what they're selling or you don't think they do, look up some threads here. There are ways to assure that your new old receiver makes it there in one piece. Buying a broken receiver is a crapshoot--it may need simple cleaning or someone may have damaged it badly.
