stronk skonk
Hello all,
I recently picked up a low wattage (speaker is rated for 2 watts) amp on the verb, and it has a few issues. I think it needs a cap job, because after a few minutes of playing on higher volumes (so far higher volumes only) it starts humming and ring modulating. At low volumes it works just fine. I ordered some new caps and plan to swap them out though.
However, i had a few more questions maybe some people could help with. The amp doesnt seem to have a fuse, rather, it has a two-prong plug with one lead going into the volume knob which acts as an on switch, and the other lead going into the pst and coming back out and going into the switch as well.
Are there generally fuses in these older switches? Should I plan on upgrading it to have a fuse if not? Also, if i wanted to install a 3-prong plug would i need to find a new transformer? It only has 2 leads. My uneducated guess is that it wouldn't be a very good idea (or even possible) to try to affix a new plug into the pst since one of the leads is winding into the transformer.
I'd be happy to upload pictures of the circuit later. Unfortunately, there doesnt seem to be any schematics on the internet, although I could search a little harder. I'm breaking into repair as a hobby and i'd like to understand as much as possible before i even plug this thing in to work on it.
I'd appreciate any help, thanks!
