Yes. Actually, the MI-1433 woofer can be found as far back as 1936 catalogs. It was made by Magnavox.Am I correct about the time frame? 1940’s?
Interesting, yeah I wonder why that's missing and everything else is together. The building it's all in was also once a Radioshack in about the late 80's to early 90's, don't even get me started on what's left over from that. I'll check the attic and make sure it's not up there with the rest of the Radioshack stuff.Yes. Actually, the MI-1433 woofer can be found as far back as 1936 catalogs. It was made by Magnavox.
It would be interesting to know what happened to the HF horn and driver that was almost certainly part of the sound system. RCA made a few large multicell horns for those systems.
I'm sorry. What is OP?Just a guess, but to achieve tmv I would assume OP knows where to sell these items.
AK is a wealth of knowledge and I think OP is asking info only. I highly doubt these pieces are sold here unless at steep discount![]()
is that label on the speaker box? can you take a picture of the back of the woofer, showing the magnet and any other markings? 18" drivers are not common. also, that might be fixable, by replacing the surround VERY CAREFULLY (learn how on less valuable woofers, or send to a pro who really knows how to baby it); if you want to resell, leave it to the buyer.I started removing the speakers from the boxes. The pics are of the speaker that was behind the movie screen, it’s 18” in diameter and pretty heavy. It may be hard to tell in the photo but it has a hole in the center of it and the foam around the edges also seems a little damaged in places. How bad does that effect the value?
And also, what is the best way to clean this stuff up? The amps as well, I want to clean up rust spots without further damaging anything.
That is the picture of the back, I can get a more broad picture of it tomorrow.is that label on the speaker box? can you take a picture of the back of the woofer, showing the magnet and any other markings? 18" drivers are not common. also, that might be fixable, by replacing the surround VERY CAREFULLY (learn how on less valuable woofers, or send to a pro who really knows how to baby it); if you want to resell, leave it to the buyer.
I mean that is the back of the woofer, it’s been removed from the box.That is the picture of the back, I can get a more broad picture of it tomorrow.
For now, I would not try to fix or clean anything, with the possible exception of blowing dust off with some compressed air (and be careful around the speaker cones). Unless you're an expert in restoration of this sort of equipment, you're more likely to damage them and/or make them less valuable, rather than more.It may be hard to tell in the photo but it has a hole in the center of it and the foam around the edges also seems a little damaged in places. How bad does that effect the value? And also, what is the best way to clean this stuff up? The amps as well, I want to clean up rust spots without further damaging anything.
I found that too, but it's about all I've found.
