Vinyl epiphany tonight
I know the feeling.I've had my restored Dual 1228 and Marantz 2270 hooked up to my Wharfedale Emerald 97's for the last week,and I havent been this amazed with vinyl since my AR TT and Kef 104/2 set-up almost 20 years ago.I forgot how good vinyl can really sound.
As good as your vinyl sounds on your OM30 you will feel that same way all over agin (deja vu, again?) if you make the next two steps to a higher-end phono stage and then a MC cartridge. I listened to whatever the current edition of the Shure V15 for 10 years before deciding to try a good phono stage (Threshold FET-10pc). What an improvement over my CR-820 phono stage. Like magic, all this good music suddenly appeared out of my speakers. Then, after another ten years I tried a good MC. Put in a Kontrapunkt B (also Ortofon) and was astounded at the amount of music I had been cheating myself out of for so many years. My two vinyl epiphanys (we can use that word down here with the shrub in charge - he is an ephiphany type of guy, you know) were when I put in a high-end phono stage in 1988 and then the high-end MC cartridge in 1998. Like you said....a big WOW!! both times. But isn't that what epiphanys are about?? Seeing (hearing) the light (music)?
Now I want an Ortofon Jubilee (Xmas?).
Nice Dual!!!!
Isn't vinyl fun? Never left but I got an Anita Baker LP and have the Cd and there is no comparision. Cd's suck! They sound dead next to a clean LP. I could not believe how much alive she sounds on vinyl. I got Steely Dan's Aja Cd and LP and the results are the same. LP's rock!!!
Thats a real pretty Dual. I am considering the 5000. I have five Duals:
2 1009s
1 1009f
1 1010s
1 1229
Got a 1010s in High School. Never really left vinyl but it kind of coasted for awhile. Got back to Duals 4 years ago with the 1229 and things have gotten out of hand. Bought and sold a few to get better wood bases and dust covers. Even my older 1009's sound great. Have fun and enjoy the music;)
Regards,
Eric of Stone Ridge
It seems we've finally discovered that you can't chop up an audio signal into 184,264 pieces per second (or whatever) and then try to put them back together again with full fidelity. Something always ends up missing or changed.
My vinyl source right now is VPI HW-19 Mk III, Well Tempered Classic arm, Van den Hul Frog. In most areas it still whips any digital source I've owned- even the $10,650. C.E.C. TL-1X transport/Pass Labs D1 DAC combo I used to own.
Originally posted by chops
gpdavis2, I'll take that Kontrapunkt B off of you if you get the Jubilee for Xmas! :deal:
Man, this talk about the Jubilee, I just had to tell this: One of our best customers at work, has a system, that's just unbelieveable:
VPI TNT 5 with JMW arm and Ortofon Jubilee cart, driving a Sonic Frontiers LINE3 preamp and phono stage, into Sonic Frontiers monoblock tube amps, connected with AudioTruth solid-silver balanced (XLR) interconnects. Speakers are Martin-Logan Prodigys, with a pair of the M-L Descent subs (the big ones!) and a pair of the Tannoy "pod" supertweeters (the BIG ones, like $2000 a pair for the tweeters!).
I just got through re-building his preamp/amp interconnect cables with built-in 40 Hz high-pass filters (basically, the correct value polystyrene high-voltage caps to make a first-order highpass at 40 Hz driving the 100K input impedence of the amp)... to match the 40 Hz lowpass of the Descent subwoofer amps. He said it was like another level has been reached, with the Prodigys and the SF amps not having to handle the extreme low end anymore.
I haven't gotten to hear the final setup yet... we're planning to have a small get-together at his house, to do the final tweaks and just plain fart around listening to tunes. Bet nobody leaves early!!
Regards,
Gordon.
Oh, BTW, Audiogeek... have you hear the fancy-dancy Pass Labs phono preamp? One of our customers at work, just got one and was just gushing over how good it sounded. It'll be interesting to compare this to the phono stage in the new VAC tube preamps we have on order at work!
Regards,
Gordon.
Which one do you mean, Gordon? The 3-box X0.2? X1? I had a chance to get an X2 at the time I had the D1 DAC, but I was already well-invested in an Audible Illusions M3 with the John Curl phono board, as well as the ARC LS-25 (6H30 tubes), so I 'passed' on it. ;)
Unfortunately, I haven't yet had the chance to get an ear on the most recent top Pass pre's. Pity, because I'm convinced they would hold their own with some of the best out there. It's a trip to NYC though.
I'm still lusting for a big, fat Pass X-series amp, or maybe a pair of X150's with a high-pass filter to the satellites as you described above, with a nice REL Stentor III doing the heavy lifting. I'd like to do this with a pair of M-L CLSII A's or Z's, if/when I come across a very good used pair. (Out of production now) I owned a pair in the early 90's and should have kept them.
No slouch the VAC's either I'm sure, but I'd also have to make a run to NYC to hear those. I'm able to check a few decent brands in my area (Albany, NY) like B&W Nautilus, Maggie, Totem, Sim Audio, JM Labs, McIntosh, Nottingham 'tables, but not a wide selection of high-end dealers here anymore.
But I usually do audio component upgrades/mods during the winter months. Since I'm also an avid cyclist, (bicycle, not motorcycle) as much as an audiophile, I've recently upgraded the parts group & wheelset on my road bike with Campagnolo, with a few other changes in the pipe to come as well. Audio will have to wait!
If you have not listened to the Threshold FET ten/pc phono stage, one of Nelson Pass' earlier designs you might want to do so. It is the best phono stage I've owned and I've not heard anything better to date. Generally can find one on da' Bay or Gon.
Glad to see other cyclists on here. And Campy too, no less. I ride a Record equipped Dean Ti and Centaur equipped Scapin.
Audiophilia and cyclophilia. Two great afflictions.
I've heard a lot of good things about the Threshold Ten pre back in the day when they were current, as much as the Pass Aleph P and L. Always wanted to get my hands on a Ten to hear it.
I had a Cannondale full-sus MTB, and an '00 Litespeed that I specced from the frame up with one of the first Record 10 groups available in the U.S. at that time, when Campy first introduced their 10v. Had sew-up Shamal's and Nucleon's, a couple pair of custom clincher's on Record & Chorus hubs - the whole 9. Well, I pretty much had to quit the MTB scene and sell the Super V after my last broken wrist and a new baby. (I guess when they're born, they're always "new" aren't they? ;) )
I'm really a roadie at heart anyway, so I didn't mind too much about the MTB. A couple of years later however, the Litespeed & bits went 'down the road' to help pay for the divorce lawyers after her and I split. I did mind losing that one, (I mean the bike!) :grumpy: :uzi:
Wasn't ready to get back to the endorphin rush until last summer, when I figured I'd go for a semi-happy medium and found a great deal on a leftover K2 cyclocross rig, since I could have only 1 bike anyway, (still feeding the lawyers). Put up with the Sh!tmano until last week, when I replaced the drivetrain with new Centaur and some nice Zonda's. I'm patiently waiting for the release of Campy's new CT cranksets, matching FD, and improved Centaur BB to complete the drivetrain, (supposedly next month).
Now life - at least when I'm on the bike - is somewhat redeemable again. :sing:
How do you like the Dean? I've been wanting to get back on a Ti frame since the Litespeed went kaput, and I've considered the Dean's. They're a tad more cost-effective than a new Tuscany or Classic, but are they noodle-y or no ?
I'm struggling right now with whether or not to purchase a FET ten/pc. I am listening to a really nice Yamaha B2 and am selling my MX-1000 as a result and need to upgrade my pre to something with a remote (I have sooooo many interuptions from the WAF and grand-kids that require "immediate" attention). So am not sure whether to turn.
The Dean El Diente.......I've had a strange relationship with this bike. I had my Record group (like yours, first year for the 10-speed) on my '87 Paramount and then my '02 Scapin. But got the ti bug. My riding buddy from way back now lives outside of Boulder and became friends with one of the people at Dean. So I got a good deal on a frameset and built it up with the Record group, Kysriums and a Sub 3 fork. And it is the best handling ride I've ever had. And its comfort, as far as road bumps and ripples, etc., is also the best. And no hint of noodling. I did 600+ miles in the Rockies this summer and it was rock solid at 50+ on the downhill sides of several mountains. But.... I just can't find a comfortable position on it. The Scapin and Paramount are much better for my 56 year old body. Want a good deal on a 54cm frameset (I want to sell it with the fork and CK headset)? $950 gets you a Dean with ~1000 miles on it. And I'll toss in an '04 Record FD (carbon).
You'll have to sell both Yamaha units to get the Ten? What then for an amp? But certainly the Ten is a noticeable improvement over the B2, (not to bash the B2).
Would I take that deal in a NY minute? - O HAil Yass! But I'd need at least a 56. :sadwave:
Now I ask you: why can't I be a bit shorter? :dammit:
Speaking of forks - actually, on the '00 Tusc that I had, I could make up for the slight frame flex with a Wound-Up CF straight fork. I wouldn't say that overall that frame was a noodle, but it wasn't a hard-assed CAAD 3 C'dale frame either. But the whole point of a Ti frame as you know is they're comfortable on the long haul.
Anyway, fast descents and general handling were improved with the addition of the WU, but that caused the front end to be a much harsher ride than I expected. Perhaps other forks would have been a better match.(?) But by then of course the steerer was already cut and mounted.
Are you gonna eBay the Dean? How about putting it up on RBR Classifieds or the Campy Only! site? I'm sure at that price you'll sell it quick.
I am also looking at one of the T-series of Class A Threshold amps. A general overall upgrade. I A/B'd the MX-1000 and B2 for the past two weeks and couldn't hear much of a difference. The MX-1000 might have just the barest shade better top-end extension and the B2 just the barest shade better bass slam......but really a "six of one, half-a-dozen of the other" thing. To be honest, my final decision came down to the fact that I like the looks of meters with needles better than I like the looks of meters that use red bars. But I am going to rebuild the back of the B2 in order to get some decent speaker terminals installed. Really not a big deal, as plenty of room to work with. Think I can do without butchering anything so can return to stock configuration, if needed.
I'll probably put my Dean on eBay come March. That's when one can get decent money for used bikes/parts as everyone gets ready for the upcoming season. Check out the Dean website. They sometimes have good deals on cancelled orders that have been built. I not longer post on Campy Only. Have never sold a thing there and always end up with about 100 spams from Nigeria.
One on Audiogon for $615 with two power supplies (the original and another one) and one on eBay for $750. I paid $1100, new, in 1987. Holding their value pretty nicely, I'd say.
now THAT"s the ticket! ML CLS full-range panels, with subwoofers. I've heard (briefly) this combo with Vandersteen 2Wq subwoofers, and man... it definitely one of those experiences you a) don't want to end, b) remember eternally, and c) want to re-create for yourself.
As for subs: IMHO, I like the Vandersteen and ML subs better than the REL's, at least if the subs are going to do duty in anything larger than a very small room. The Vandersteens and MLs have all the resolving power of the RELs (or are at least within an infinitessimal degree of the same resolution), with MUCH more effective bottom end extension. Both the Vandys and the MLs easily dig below 20 Hz, with GREAT control and dynamics, especially when used in "stereo" pairs.
Also, if you use the Vandersteens... they COME with a version of the highpass filter I was discussing above, to go between the preamp and amp, as original equipment (in fact it's NECESSARY for the subs to work properly!) ! Makes it REALLY EASY...
Now, I haven't gotten to hear a pair of the CLS's, with BOTH subs AND a set of the Tannoy supertweeters. I can just imagine how much pants-wetting might take place if THAT combo were implemented... :eek: :D
Regards,
Gordon.
Gordon,
Which REL's did you hear with the CLS'? I owned a Vandy 2W for a short while, back in the early-90's when I had the CLS IIa's, as well as an Entec, and compared to what I've heard with the REL Stentor III, the REL has at least the resolving ability and low-end extention of the 2W, and I might say even more. I thought the Entec actually did the best job until the "III" version of the Stentor hit the market. But 2 caveats:
A: The 2W I had has probably been improved upon with the 2Wq.(?)
B: IMHO, the REL ST-series from the Stadium III down are very good subs, but do not measure up to the 2 top units, Stentor III & Studio III. I'm not sure what accounts for this, but I would first point the finger at the 'Super-ARM' loading and 'Big Volt' drivers of the Stentor/Studio, which the Stadium, Storm, and Strata do not employ.
To that end (B), I had purchased the Stadium III first (in '00) hoping I could skirt paying the higher price of the top model's and still have the performance level I was seeking. But as you're probably aware with the high-end, one can often find a very suitable component that may not be the most expensive in its class or among the very top models of a mfg's line, but more often that not you have to "pay the piper" to reach certain levels.
With the Stadium + a pair of Nautilus 803's (run full-range), driven by a fairly resolving tube front-end, the overall impression I had was of a sense of dryness and slight constriction or lack of complete fullness with the Stadium. After 2 weeks of continuous play time and repositioning, I thought I'd trade the Stadium back to the dealer for a Stentor.
Well, I can say that the Stentor was a revelation to me. It seemed the low-end was now whole and complete, very speedy and unrestricted, (ease of presentation or "relaxed"), powerful when needed, and went lower than I thought was possible in that particular room. I think the end result would have been even more impressive with the 803's cut off at about the 40-45Hz range.
Is the Vandy high-pass configurable, or set at a given freq/slope?
