Preston;
If you really want to get into it, like so, you will need to do like I have.
You have a DMM and it has its uses, here, but not so much for calibration.
You are going to want to use a dual channel O'scope, phase and head height will meter well, with that. A dual channel AC millivolt meter that you can use to set output levels. And an audio frequency signal generator. Import a signal and monitor it with the other equipment. You can set levels and alignment of the record and erase head that way. And, of course, a test tape. Set the playback (Pb) head with that.
I can get by with that but it is a minimum of equipment. It is enough for starters, though.
As I have, you may find that you have set yourself up with a good sounding low frequency and then, when setting up for 10K, there isn't enough there, to adjust equalization AT 10K. It's because the head isn't quite in the right place yet.
Your looking for a maximum output at all audible frequencies but that isn't all ways possible. You nay find that output levels at low frequencies are good, with the Pb. head in one place but better at another, for the highs. Again, the heads are not quite there, yet. In that case, you need to go for a compromise. Find that spot where both the highs and the lows can by adjusted to a similar standard level.
The first time through it all, kind of 'gets you in the neighborhood' let's say. So, after that, back the test up and go through it all again to tweak it. And then, back the tape up and do it again. It's like 'limits' in math, each time, you get closer to the right place for a tape head.
After a while, I think you will find, that setting up a deck becomes more of an art, through time, practice and experience. Nothing wrong with spec. levels and you should find those first, but, as many members in this forum can attest to, you get to listen to music the way you like to hear it, with these things.
All this applies to the Pb. head but, the same thing goes for the record head, as well. You want 'it' to put a signal on the tape so the Pb. head can reproduce it right.
The erase head should be set to take off as much recorded signal as it can, with out removing any signal from the other side of the tape. Recordings are made on tracks 1 ans 3 on a 4 track/2 channel deck so you don't want to remove any signal from tracks 2 and 4.
I have no idea how much you all ready know about setting up a deck this way but, just thought I'd write in my experiences doing it.
Best of luck, carry on. I'd love to read more.
Lu.
