Hey All,
I picked up the VM 804 console a few years back from Audio Archaeology in Chicago (https://www.audioarchaeology.com/vintage-audio) as a gift for my wife.
I fully expected that it wouldn't work and I'd have to do some work on it, but I was pleasantly surprised to find out that it played records and sounded pretty good when it arrived! The only issue was that the speed of the platter would intermittently vary, annoying but my wife thought it gave it some character... I did not.
So I found Gary Stork at V-M Audio Enthusiasts in Michigan (https://www.thevoiceofmusic.com/) and he hooked me up with a replacement idler wheel and all of the instructions, manuals, and schematics to fully refurbish the turntable which I did and now it sounds terrific!
I haven't done anything with the built-in 20037 amp, it seems fine, though I have ordered some replacement tubes from The Tube Store in Canada (https://www.thetubestore.com/) to try to see if it improves the sound at all.
Oh, and I have it plugged in to power through a Tripp-Lite isolating transformer which has helped the unit produce a cleaner sound.
My question is this, I'd like to split the audio that is coming out of the turntable so that it still goes to the internal 20037 amp but so I can also route it to my modern Sony stereo amplifier to get the audio into the main room of the house.
There are 2 RCA type connectors for L and R on the underside of the turntable and I have connected 2 RCA Y-adapters (1 male to 2 female) to the turntable. I reconnected the RCA wires to the amp and that all works fine.
The problem comes when I connect anything to the other pair of split L and R wires, the VM 804 speakers start buzzing really loudly and no sound gets to the Sony amp.
I have assumed that I'll need a phono pre-amp for the audio coming out of the turntable but those usually require a ground wire from the turntable to the pre-amp and the 1223 turntable does not have a ground wire or even a ground wire connector that I've been able to find on the unit.
Anyway, obviously I am not an expert on any of this (I only know enough about reading an electrical diagram to get myself into trouble, ha!), so I'm reaching out to the smarter folks here to see if what I am trying to do is even possible, and if so, how I might be able to do it.
Thanks in advance to anyone that wants to chime in on this!
