Volume knob size? - Model 2385, 2500, 2600
slowpat
Slowly but surely....
I just bought a 2500 with missing volume knob. Can any owner of the 2385, 2500 or 2600 tell me if it's a standard sized knob or is it slightly larger. All I know is that it should be solid aluminum with set screw....thanks!
Both my 2285 and my 2270 have the exact same size volume knob. 2.3 millimeter across and all the single knobs are that size across each amp. Hope that helps!
Mark
2 set screws actually. The knob is physically the same size between the 3 you listed and the standard 22xx blue dial scale knobs. If you have a spare one, take the next size up drill bit and drill the splines out of the plastic. It will push on with enough grip to the smooth shaft of the 2500 and still look decent until the proper knob shows up- as you know we are both on the hunt, may the best man win :D.
Thanks Mark..
And thanks BK for the info...yes, the hunt is on! :D Whatever happened to the custom made knobs that you were pursuing??
4seatpilot's cousin was supposed to redo the first run but he's dropped off the face of the earth. Steve has pinged him multiple times without an answer. :(
