I don’t think specific brands have a influence to my question- I have a 35 WPC stereo tube amplifier; global negative feedback is taken from the 8 ohm tap of the output transformer. One set of speakers are 8 ohm with 93 dB efficiency, the other set are 4ohm with 93 dB efficiency. The 8ohm speakers operated from the 8 ohm tap are noticeably louder than the 4 ohm speakers operated from the 4 ohm tap. Same thing occurs with another 4ohm set of speakers of lower efficiency are tried.
It seems like the entire output level drops as the hum and noise is at lower volume also, and the volume control has to be advanced maybe 15 degrees for the same volume. Both channels are the same and sound quality is excellent.
Doesn’t seem to happen on another tube amp that I have......and have never noticed this with guitar amps.
Anyone have an opinion about this ?
