Hi all. I’ve been restoring a Bogen AP-60 integrated amp. Only issue now is that the volume suddenly goes from quiet to overkill when turning the volume knob. Was mainly doing it on 1 channel. So I cleaned the pot and now both channels seem to be doing it, but maybe at a different volume setting than before (like at 5 instead of 8). Same thing happens if I connect to either the local or remote speaker connections. Does this just sound like a bad pot? Just checking if anyone had another idea in troubleshooting before replacing the pot. It’s one of those double knobs where the front and rear control the different channels. Lots of connections so don’t want to take the pot out unless it is the most likely culprit. It sounds great just the volume seems low and then spikes suddenly at a certain volume setting. Thanks
, he probably didn`t use Caig Fader cleaner/lube spray, and used Deoxit instead and could have trashed the ganged pot`s carbon tracts. !
