Yes, provided you have the correct diameter Platter for the HW-19, all will work.
The Springs had threaded Studs, which will screw into the T-Nuts at all 4 corners.
As I understood, these springs could have different gauges-strength, so, some experimentation may be required to insure the inner Plinth sits totally level within the wood Base.
Another important consideration, the Tonearm? If you're going full blown with a MK-III or MK-IV assemblage, this might then likely have the Steel Sub-Chassis, and a separate removable Armboard.
Any decent Plastics company can whip a new blank Armboard up lickety split, some folks have simply made new Armboards from whatever woods they like-find, or Corian, some leftovers from a Kitchen Countertop project?
The Base, countless things can be done/re-done, and in the end, this table could look like a million.
Let's say you're missing a Dustcover. OK, there's likely people out there 3rd party who make such that will fit precisely, and could be probably ordered in various heights. 4" or 5" tall was what VPI used.
I will say this, and so will others, the Stock Dustcover, while it looks nice, can also degrade the Table's performance-sonics. A larger lift off custom Acrylic Cover would be the best in truth if you're looking to squeeze all the performance you can from this Table.
These tables, because of no stock provision for adjusting-tuning precise speed is a downside with AC Syncro Motors such as they use. Without a Speed Controller, I'd likely be correct to say all HW-19's and other VPI variants of this time era all had this particular issue (Aries-TNT-etc)
And such as the TNT's were no better, especially some of their Tables with Idler Pulleys, multiple Belts, a real can of worms.
And there was cures, such as the VPI PLC (2 Versions) and the VPI SDS.
My HW-19 always ran slow, either with the Stock Junior 6lb Platter, or the 1st version Lead Ring all Delrin HW-19 MK-IV Platter. I bought a brand new SDS at a very fair price of $750 US.
That was a major upgrade, my music was now in perfect pitch, and time, or as was intended to be, or recorded as. I could easily tell the fairly substantial lag for some time, as I play drums and bass.
There are no parts from VPI for the HW-19. They might have the little Tungsten Thrust Plates for the Platter Bearing, they're about the size of a Baby Aspirin.
