RTFM.
Read the Scoutmaster's manual to find the answers to all that you need to know about aligning your cartridge, VTA adjustment, azimuth adjustment, etc., for the JMW arm, read it, follow it...if you bought yours used and do not have that arm, well, all bets about that are off...if you don't have a manual, get one from VPI...you also need a good stylus weight gauge, the ubiquitous Shure scale is out there, I use a digital one I got off the web that measures down to .01g and cost under $30 shipped....
Also you can go
here and
here to find out more about proper setup....
Vinyl takes cleanliness....it's not like a CD...you have to take proper care of your gear and media...half assed procedures lead to half assed results...
The LAST products are great, I use their vinyl treatment on PROPERLY CLEANED new LP's to protect them, and have done so for about 30 years now, and to listen to records treated back then is amazing...clean and quiet...I might not like some of the music from then any longer, but the records are pristine, even after all the plays they have been through...I also would take the cleaned and treated records and put them into the old Discwasher VRP "rice paper" sleeves, now I get them from Bags Unlimited, or Sleeve City...but any time you clean a new record properly you must put it into a new, high quality, sleeve to protect it from surface abrasion or scratches...putting it back into the old paper sleeve might just negate all the care you've just lavished on your LP...
I've used the LAST stylus cleaner in the past, but use LP #9 and Mr. Clean Magic Eraser now, search this forum and you'll find out about the ME and how to use it to keep your stylus clean and shiny...always clean the stylus before each play.
Today we analog lovers have more tools available to us than ever, especially when it comes to proper record cleaning....once upon a time the Discwasher was thought to be a good way to clean records...today, especially after the proliferation of record cleaning machines and improved manual procedures, we know better....I quit using any of my Discwashers after hearing what it did to a properly cleaned record, all it took was once to hear the degradation that the DW did on that cleaned record on one side compared to just a simple CF brushing on the other...and I
knew this album very well....
Carbon fiber brushes are great, for cleaning the dust off of properly cleaned records...you must clean your records properly or all the brushing with a CF brush isn't going to really do much for you...you've got to get the grooves clean, get the mold release compounds off the new records and the crap down in the grooves on older ones, before the CF brush really does anything for you....
There is information on the
Disc Doctor's site,
here and
here, on how to use modern record cleaning materials and special brushes to properly clean records without using a machine...I used the Disc Doctor's stuff for a couple of years before picking up a VPI 16.5 and while the manual way worked better than anything I had ever done in the past, the vacuum machine took it to a whole different level....that and switching from the Disc Doctor's fluids to the Audio Intelligent Vinyl Solutions products...I've used the VPI for nearly a decade and I have to say it is the best analog accessory that I have ever bought....you have to learn how to properly clean you records to really see what kind of quality your vinyl rig is going to deliver.
You have a nice table, a decent enough cartridge, and obviously have taken care to get a setup that's definitely beyond entry level, so it's time for you to step up to the plate, start with proper vinyl hygiene and learn how to set up your turntable, both of which will definitely take your enjoyment to another level!
Good Luck and Have Fun!
