rockinrob86
EDIT AFTER ISSUE WAS FIXED. I was having issues with cheap replacement tweeters for my Klipsch speakers, and also some hum coming from stacking the ST70 on top of my preamp. I also was using old preamp and power tubes, that although they "worked" were not nearly up to spec. Kegger gave me some mods to do later on, but I hadn't fixed my other issues before I did them. At this point, with titanium tweeters, good tubes all around (Ampex 12au7s, telefunken 12ax7, a mullard 12au7 in the middle on the st70 and EH 6CA7 output tubes) it sounds FANTASTIC and beats my expectations. The bass is big and bad, but not overpowering and it handles anything from classical, jazz, etc to metal, and I am totally happy! Long story short, you cant skimp out at any stage, and new or verified NOS tubes are must haves.
I am running a tubes4hifi (aikidio with regulated power and phonostage) sp8 into a vta low gain w 12au7 modded st70 (New filtercaps, the works), and Klipsch Chorus II speakers.
The problem is there is not enough bass. When I switch my marantz (fully recapped, sounds great) back in, the bass comes back.
I know the marantz stuff is "warm" sounding, but this is different.
It sounded terrible at first( as in ouch that piercing treble really hurts), and I realized that was a bias issue caused by my interpretation of the manual(dont ask). I biased each tube to 45ma and it was better, but still light on the bass. The sound is very detailed, and really great, but just too little bass.
If I use my headphones on the marantz with the sp8 going into the tape input on the marantz it sounds awesome, and significantly better than if I was just using the marantz alone. IT still sounds detailed, and actually very similar to how it sounds with the speakers, only the bass is right were it should be.
My headphones are grado SR80s, and are far from overly bassy. They sound basically neutral.
When I am running the st70, there is bass, it just has no punch and feels that it is just out of balance with the mids and trebles. I bought parts to build a tone control to install in the preamp, but I am thinking this is not the problem, and I need to solve the real issue.
I am running JJ EL34 tubes that were in the st70 when I got it, and I dont know how many hours are on them. They bias up fine.
The power transformer in the st70 is original (I have the nickel plated earliest version).
My power at the wall is usually 122, and the PT is untouchable for more than a split second within 30 minutes or so.
I dont want to buy new tubes or a PT if I dont have to. I have other things I want to spend money on...
But, does it sound like one of these is responsible for my issue?
