Buster Caps
I recently purchased a Heathkit IM-18 VTVM . I did a thorough cleaning, visual exam, component check and calibration. Tubes have been tested and passed OK. Cross tested performance against a Fluke 179 . -- Ohms and DC functions are very acceptable. However I am confounded by its inaccuracy in the lower ranges of AC signal testing.
Inputting AC from a Variac yields very accurate results in the higher ranges. For the lower 5v and 1.5v ranges, I input a 1kHz sine wave with a signal generator . The accuracy of readings below 5 volts are about 20% lower than the DMM. A larger 30% error discrepancy is seen on the 1.5v range. In other words, 650mV on the DMM is seen as 500mV on the VTVM.
Is such an error normal for this "service grade" meter??. Is this characteristic of old VTVMs? (I've never used one before)
I was intending to use this meter for adjusting /testing analog cassette tape decks; mostly needing measurements in the order of mV. The VTVM's very high input impedance was attractive. I guess I'll stick with my DMMs unless this is something that can be corrected/improved.
Thanks for your advice.
attached: schematic
attached: schematic
