Manitoulin said:If you are using a standalone VU meter, in most cases the meter has to be protected. Mormally meters work with milliamps, your amp will push out amps of current.
You will need exact specs on the meter to calculate the correct resistor to drop the excess power from the amp so you do not fry the meter.
tennisdude said:what's mormally meters?
shrinkboy said:does tennisdude have enough posts to be taking cheap shots like that? doncha have to have, like, 100 posts or so before you get cheap shot privileges?
:yes: :yes:Manitoulin said:Was supposed to be normally... I have edited it for clarity
philmcl said::yes: :yes::yes: :yes:
PhilMcL said:does adding a vu meter color the sound in any way?
