This is a vintage Harman Kardon 430 where i installed LED's with resistor by each LED. The problem is that voltage remained the same after LED was installed and it shows AC on my DVM. I would expect LED to burn out shortly (voltage is over 6 volt and LED voltage should be 3,2 volt) and light is too bright- What to do? get a regular diode and install in series in wires feeding voltage
Would a Zener diode be better, I have this one: http://parts.digikey.com/uk/1/593081-diode-zener-6-8v-500mw-5-do-35-1n754a.html
What specs should diode have to work as intended?
Voltage being fed is 6,7 volt. LED's I am using are 3,2 V and 50 MA
