Im having trouble finding the caps I need. WJOE doesnt have most of the values I need. Mouser seems astronomically high and not much seems to be axial in the values I need. Im also confused now about the "small c" is supposed to be polarized or not? I thought only electrolytics were polar?
I usually use Digi-Key because of the free shipping option, see my post with link earlier in this thread.
For such a small value cap (the small c) film caps, which are not polarized, are very affordable so there's no need to use an electrolytic, although you could. Motor run caps are film but they are physically large because their normal use puts a lot of stress on them. They can be used anywhere in your PS if you have the room. Here's a good source:
https://www.surpluscenter.com/Electrical/Capacitors/
I've never bought any from Digi so I don't know how their prices compare if you take free shipping into account.
I'd probably just use a regular 630v film cap, such as you would use as a coupling cap, in the small c position.
Here are some 220uf 450v with the ratings I suggested:
https://www.digikey.com/products/en...tity=&ColumnSort=0&page=1&stock=1&pageSize=25
And a 470uf 450v:
https://www.digikey.com/products/en...03a&quantity=&ColumnSort=0&page=1&pageSize=25
These are all what's known as "snap in" style caps. The connectors are short but they're not hard to work with. If you use terminal strips, they are spaced so that you can solder them to the tabs on the strip. You could also mount them in other ways in which case you just put a little bend in the connector and solder a wire to it..
I forget which schematic you're building but I would guess the 40uf would be a cathode bypass cap. Maybe you could post or link to the schematic so we can be sure. Typically, you would use an electrolytic there. Voltage rating would be much lower (if it's a cathode bypass) and you're not as likely to find something in 40uf so go with a 47uf. Again, post a schematic so I know if that's what it's used for in the circuit.
Axial caps are not nearly as common as radial or snap in style and they will be more expensive, usually.
