HidetheHiFi
TL;DR - Is stated power output highly overvalued?
I don't suppose I'm the first person to comment on this, but as someone still in the honeymoon period of vintage audiophilia, I'd be interested to hear some community wisdom on the question of power output. Or more specifically, its relationship to "how loud the thing goes", if that's not too crude a term.
The context: my love affair with hifi re-ignited over the 2020 lockdown and has been focussed on 1970's kit, and specifically, Japanese-made receivers. In a relatively short space of time (they're not making any more, quick, you might never see that one again!) I acquired a number of units from Pioneer, Yamaha, Rotel and Luxman, all rated between 25 and 50 watts.
The confusion: The two more powerful units (sx780 and sx750) did sound louder than the 25/30w units, and so with some excitement, I sold my old Saab (wasn't getting used) and increased my budget to some upper-mid level machines, notably a Marantz 2285 and a Luxman R-1120. With 85w and 120w respectively, I assumed these were going to offer intoxicating, near limitless reserves of power.
I was wrong.
They sounded maybe a "bit" louder than the two Pioneers, but not my much. In fact it may have been wishful thinking as I'm not completely convinced the Sx780 doesn't still have them both beat for sheer grunt.
The research: so I started to read up on the relationship between power output, and decibels, and decibels and sound pressure. I got confused. But my take away from that was this: a 40w amp is certainly not twice as loud as a 20w amp. It's really only a little bit louder. If you want to get an amp that sounds twice as loud - then you'll need a 200w amp.
The questions:
1. That may be over simplistic, but my experience seems to suggest it may not be far off the mark. Can any of AK's more technical members corroborate that ballpark 10:1 power output ratio required to double perceived volume?
2. Also, if that is the case - and apologies if my post starts to trespass here into values territory - why the huge premiums paid for high power machines if the difference is volume is really quite modest? I realise some of the bigger receivers have better tuners and more speaker outputs, but it seems equally true, especially for, say, Marantz, that the lower power machines sounds just as, if not, sweeter than their bigger brothers.
3. I have also noticed that the CD out signal (from a Marantz CD73 and Philips CD160) sounds noticeably louder than other sources such as the built-in tuner or playing my iphone via iFi Zen Blue DAC into aux. Why is that? Because it's a higher voltage? Could you increase the voltage on any source (eg a DAC) and reap similar "gains" in volume? Is there any risk to amp/speakers from "louder" sources?
4. I also read - on AK I think - that Pioneer tended to calibrate the volume control so that most of the welly comes before the midday position, and after that, there's not much to give. Is there any truth in that? It's hard for me to test as most of the units I have are already pretty damn loud by that stage and I wouldn't want to risk blowing up anything by going into the afternoon, as it were. How many on here regularly crank up the volume past the half way mark?
5. I read people talking about "headroom" and how good it is to have power in reserve, but is there any science in that? I mean it's not like we're driving and we need power in reserve to overtake. If you had a blind test with an sx450 playing at 50% and an sx950 playing at say 30%, so that the sound level seemed the same, would you be able to tell the difference?
Thanks in advance for anyone with the patience to read this far and consider any of these rather ill-informed queries. It would help me allay current suspicion that, for the great majority of speakers, especially if only one pair is connected, having anything over 50 watts is probably overkill.
Craig
ps 1. I appreciate this is not a very sophisticated line of questioning, and that volume/power output is only one part of a system's ability to entertain, but who doesn't enjoy that moment when the volume dial is only at 2.5 and you can feel the floor vibrating already ; )
ps 2. Receivers normally tested with Celestion Ditton 25s, but also Beovox M70 and S45, and a modern pair of Monitor Audio (Monitor 50). The woofers on the Dittons are nearly 50 years old and positively heroic in their ability to move air
I was wrong.
The questions:
Craig
