Weird Hum from Heathkit SP2 Preamp
david24x7
Hi. I just finished recapping all the electrolytics in this preamp that I've been using for some time (better late than never). I had some issues with recitfier diodes but I've worked that out and I had eliminated the 60 cycle hum that given me trouble.
After I got it back on the shelf (and since), I'm getting this unusual noise from the speakers. It's less of a constant buzz and more of a 60 cycle rhythm. I'm not sure how to describe it, so here are 3 short (10-15 sec) videos so you can hear the sound for yourself.
Can anybody help me figure out what might be causing this sound? Volume is at about 3 on the dial so it's pretty loud and annoying.
Yes. I let my Dynaco ST-70 warm up first and no hum until I turn on the preamp and after it warms up, it starts this weird hum. Do you think it could be a tube? I had tested all tubes last week before this started happening and they all tested good but maybe something got knocked lose while I was working on the recap and troubleshooting a different hum (which was fixed when I resoldered all the joints on the new caps).
If it is in both channels, the power supply. If in one channel, something in the feedback loop.
Test it without a connection to main amp. Perhaps via headphones. Always good to first confirm it is just one device, and not related to any example external connection.
I have seen it on a different preamp a long time ago,I think the selector switches were dirty on that one.If it was ok before the recap,I would check the values of the replacement caps against the schematic, or a poor ground on one of the downstream electrolytic power supply caps
The hum is in both channels but much louder in B channel and the oscillation is only in the A channel. The new caps are marked with same/similar value as the ones that I took out but I'll break out my capacitor meter and verify. I did clean the contacts with contact cleaner before all this noise started so maybe that does have something to do with it - esp since it does not affect the AUX inputs and only the Mag Phone and Tape/Mic to a lesser degree.
Thx for all the good tips. I'll keep you posted on the results.
Hmmm. It is in both channels though greater in Channel B than Channel A. And very little hum in the AUX inputs - only Mag Phono, Mic and tape.
FYI - I've exhausted what I can do so I've brought her to my local tube stereo repair shop. Hopefully, it's something simple. Cross your fingers.
