Ben Rothman
Hi guys, I have a restored SX-1010 that I have used for about a year since the restoration. It got the works during the restoration, including the brand-new power supply board. It's been working flawlessly until recently when the sound started to fade in and out for no reason. I immediately thought it was dirty switches and cleaned everything (minus the pots), but the issue persisted. The volume and balance pots were smooth as silk and made no noise when operated, so I didn't think that was the issue. I eventually cleaned the volume and balance pot and the issue went away, sort of. When I let the unit sit overnight, if I turn it on, I get no sound out of the left speaker at extremely low listening volumes, but the sound does come out of the right channel. If I turn the volume up a tiny bit, the sound kicks in on the left channel, and it doesn't seem to go away. It will even work at the very low listening levels where it wasn't working before.
So I cleaned the volume pot again with Fadbrlube, and that fixed the problem right away, but if I let it sit overnight, the same issue came back in the morning on the left channel. If the volume pot is dirty, I don't get how moving it the most minuscule amount makes sound come through on the left channel, and then it works at the volume where it wasn't working before. I have sourced a replacement ACV-134 volume pot, and it's on the way. I'm unsure if the issue is in the volume pot, but I think it is. No other switch can get the sound to come back in except the volume knob.
I've read that the pre-out/main-in jacks could be dirty, and I haven't tried cleaning those, but I wanted to get some other opinions first. I know it's not electrical, like a capacitor or transistor. I believe it's a mechanical issue. Are these pots known to go bad?
